Interface PIC16F887 with PC (VB.net)
Hello ..I'm doing my FYP and am having problems with getting data from the PC (vb.net) to the microcontroller (PIC16f887) that will be displayed in LCD 2x16 .. The problem for example I wanna send (hello) to the microcontroller so I get ( hlo) instead of ( hello ) or sometimes i get the 3rd digit or char that am sending from the textbox in VB.net.. for the communication between the PIC and PC am using USB to UART converter ( UC00B ) and am using (SK40C) for the microcontroller .
Plz if there anyone could help with this or anyone has similar code .. Thanx in advance
here are my codes
PIC16F887 code:
The VB code :
here are my codes
PIC16F887 code:
- CODE: SELECT_ALL_CODE
// include
#include <pic.h>
// Configuration
__CONFIG(FOSC_HS & //External Crystal at High Speed
WDTE_OFF & //Disable Watchdog Timer
PWRTE_ON & //Enable Power Up Timer
BOREN_OFF & //Disable Brown Out Reset
MCLRE_ON & //MCLR function is enabled
LVP_OFF); //Disable Low Voltage Programming
// Define
#define rs RB4 //RS pin of the LCD display
#define e RB5 //E pin of the LCD display
#define b_light RC1 //backlight of the LCD display (1 to on backlight)
#define SW1 RB0 //button (active low)
#define SW2 RB1 //button (active low)
#define lcd_data PORTD //LCD 8-bit data PORT
#define LED1 RB6 //led 1 (active high)
#define LED2 RB7 //led 2 (active high)
// Function prototype
void lcd_clr(void);
void send_string(const char *s);
unsigned char uart_rec(void);
void beep(void);
void uart_str(const char *s);
void send_cmd(unsigned char num, unsigned int data, unsigned int ramp);
// Main function
void main(void)
unsigned char a;
PORTA = 0; // Clear Port
PORTB = 0;
PORTC = 0;
PORTD = 0;
TRISA = 0b00000000; // set PortA as OUTPUT
TRISB = 0b00000011; // set PORTB<1:0> as INPUT
TRISC = 0b00000000;
TRISD = 0b00000000; // set PORTD as OUTPUT
ANSEL = 0; // Set PORTA as Digital I/O for PIC16F887
ANSELH = 0; // SET PORTB as DIGITAL I/O for PIC16F887
//setup USART
SPBRG = 0x81; //set baud rate to 9600 for 20Mhz
BRGH = 1; //baud rate high speed option
TXEN = 1; //enable transmission
CREN = 1; //enable reception
SPEN = 1; //enable serial port
TX9 =0; //8-bit transmission
RX9 =0; //8-bit reception
//setup ADC
ADCON1 = 0b00000110; //set ADx pin digital I/O
//configure lcd
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //lcd return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //display on, cursor off and cursor blink off
send_config(0b00111000); //function set
//infinity loop
//uart_init();
while(1)
CREN=1;
a = uart_rec();
lcd_clr();
lcd_goto(0);
send_string("The value is:");
lcd_goto(20);
send_char(a);
CREN=0;
// Functions
void delay(unsigned long data) //delay function, the delay time
{ //depend on the given value
for( ;data>0;data-=1);
void send_config(unsigned char data) //send lcd configuration
rs=0; //set lcd to configuration mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay(50);
e=0;
delay(50);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
delay(10);
e=0;
delay(10);
void lcd_goto(unsigned char data) //set the location of the lcd cursor
{ //if the given value is (0-15) the
if(data<16) //cursor will be at the upper line
{ //if the given value is (20-35) the
send_config(0x80+data); //cursor will be at the lower line
} //location of the lcd cursor(2X16):
else // -----------------------------------------------------
{ // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
data=data-20; // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
send_config(0xc0+data); // -----------------------------------------------------
void lcd_clr(void) //clear the lcd
send_config(0x01);
delay(600);
void send_string(const char *s) //send a string to display in the lcd
unsigned char i=0;
while (s && *s)send_char (*s++);
unsigned char uart_rec(void) //receive uart value
unsigned char rec_data;
while(RCIF==0); //wait for data
rec_data = RCREG;
return rec_data; //return the data received
while(TXIF==0); //only send the new data after
TXREG=data; //the previous data finish sent
while(*s)uart_send(*s++); // UART sending string
The VB code :
Imports System.IO.Ports
Public Class Form2
Delegate Sub AddText(ByVal Text As String)
Dim myEnc As System.Text.Encoding = System.Text.Encoding.GetEncoding(28591)
Private Sub SerialPort1_DataReceived(ByVal sender As Object, _
ByVal e As SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
Dim br As Integer = SerialPort1.BytesToRead
If br > 0 Then
Dim b(br - 1) As Byte
br = SerialPort1.Read(b, 0, br)
Dim s As String = myEnc.GetChars(b)
RichTextBox1.Invoke(New AddText(AddressOf RichTextBox1.AppendText), s)
End If
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
If SerialPort1.IsOpen Then
SerialPort1.Close()
Else
Try
SerialPort1.PortName = "COM8"
SerialPort1.BaudRate = 9600
SerialPort1.Encoding = myEnc
SerialPort1.Open()
MsgBox("The port is open", MsgBoxStyle.Information)
Catch ex As Exception
MessageBox.Show(ex.ToString)
End Try
End If
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
SerialPort1.Write(TextBox1.Text)
End Sub
