Integrate data from sensor to database using PIC16f877a
Postby bella » Wed Nov 18, 2015 2:36 pm
Greetings ,
I have problems regarding my final year project . Im using three sensor to monitor a plant . The sensor that I use are soil moisture sensor , LM35 for temperature sensor and LDR for my light sensor . These three sensor should be able to collect data and store it in database since Im not using LCD to display my data . Im using bluetooth module to transfer data to my database . The problem is , how to integrate the data collect into database using these bluetooth module ? Last , Im using PIC16f877a microcontroller .
bella
Re: Integrate data from sensor to database using PIC16f877a
Postby Nurul.Syuhada » Wed Nov 18, 2015 5:57 pm
Hi, Maybe you can refer to this tutorial. Hope it may helps. :geek:
Nurul.Syuhada
Postby yonghui » Wed Nov 25, 2015 10:02 am
your question is not clear
how many bluetooth do u have?
u better start by project by writing simple code like LED blinking first. make sure it works.
then u can start try to use adc to read the analog values.
then only u start do communication with bluetooth. btw i dont know where u want to transfer the data thru bluetooth.
