RELAY
RELAY
Postby loh21395 » Tue Feb 23, 2016 6:45 pm
RELAY
anyone can help me to chose a suitable relay? thankq so much!
AC MOTOR 1200W 230V
POWER INVERTER 2000W DC12V IN AC230 OUT
BATTERY 12V/8.2AH
I want to find a relay that can support whit the voltage, and the motor can control by RC.thanks...
loh21395
Re: RELAY
Postby loh21395 » Tue Feb 23, 2016 6:48 pm
loh21395
Re: RELAY
Postby Idris » Wed Feb 24, 2016 8:52 am
Hi loh21395,
By referring to RCSwitch10 specs, it is compatible.
Re: RELAY
Postby loh21395 » Wed Feb 24, 2016 12:33 pm
thanks idris :D
loh21395
Re: RELAY
Postby carmen_rgh » Tue Jul 05, 2016 2:54 pm
How can i connect a 6V DC lamp to Single channel 5V relay breakout board?
carmen_rgh
Re: RELAY
Postby ZaM » Tue Jul 12, 2016 11:14 am
carmen_rgh WROTE:How can i connect a 6V DC lamp to Single channel 5V relay breakout board?
Hi, you can refer https://docs.google.com/document/d/1U9mQaoAUnMKhPvo1QPIJKJA3Ra0a5kAWEJNsmjZwvCA/edit. if your lamp need 6VDC to operate, just disconnect 5V(Red wire) from Microcontroller and supply 6V to the lamp.
ZaM
