hi all, i have bought a pair of QFM-TRX1-24G RF transceiver module which uses cc2500 from TI for my Final year project. i have read through the CC2500 datasheets but i found that there are a 72 of internal registers which i do not know which i should configure. is there anyone can help me up?
my FYP is about RF based security system, end unit and the master unit are both equipped with RF transceiver and a PIC for controlling the transmitting and receiving of the signal respectively.
The PIC will be programmed to send and receive the heart beat signal in a regular interval while the 2 units would sense the heart beat via the strength of RF signal. Address will be set so that whenever the address of the belongings is matched with the address send by master unit, the end unit will responses to the master unit. Master unit will continuing transmit signal to the end unit to ask for its existence. On the other hand, end unit is responsible to receive signal from master unit and compare the addresses. Once the address comparison process is succeed, the end unit will shows its existence by transmitting the signal back to master unit, else the end unit will keep silent. Any lost of this heart beat signal from end unit will trigger the buzzer.
