Cytron WiFi Shield
Announcement of new product, new information, ROBOTICs competition, exhibition and more.....
Cytron WiFi Shield
Postby Ariff » Wed Jun 27, 2018 2:34 pm
i'm currently doing a "project on product counter " and to upload the data to the internet via the wifi shield. I'm having problem finding the right command to upload it. Is it as easy as :
client.print(sensorCounter);
and where do i place it in the body of the program which i took from the example from the WiFi shield library (CytronWiFiDemo) ?
Ariff
Re: Cytron WiFi Shield
Postby bengchet » Fri Jun 29, 2018 8:25 am
If you are using CytronWiFiDemo, you can type following url into your browser, replace IP address with actual IP, you can check with serial monitor.
<your ip address>/ -> you will see hello message
<your ip address>/analog -> you will see your board analog values
<your ip address>/gpio2 -> you will see ESP8266 GPIO2 status
<your ip address>/info -> you will see AT Firmware info from WiFi Shield
Example: 192.168.1.10/analog
Then you read the code and can get the idea how to insert your data in your application.
Postby Ariff » Fri Jun 29, 2018 10:56 am
Ok now i have succeeded on sending data to local IP address, now i want to know if there's a way to send those data to a different url ?
Ariff
Postby bengchet » Sun Jul 01, 2018 10:29 am
HI,
Can I know what do you mean different URL? Can explain more?
Postby Ariff » Tue Jul 10, 2018 11:59 am
bengchet WROTE:HI,
Instead of sending those data to the local ip address, is it possible to send to different websites, or other ip addresses ?
Ariff
Postby bengchet » Tue Jul 10, 2018 8:03 pm
You can refer to this post.
Return to News and Event
