Balancing Robot (Minimalist Design Using Only Accelerometer)
Anything related to the ROBOT. Head to Toe Magazine.
Re: Balancing Robot (Minimalist Design Using Only Accelerometer)
Postby gilbertgan » Thu Jan 06, 2011 7:35 pm
Hi. Im new here. :lol:
My project differs with TS. My project require me to build a autonomous mobile robot to balance a full cup of water (cap opened) when it's going up a 30degree slope. Im thinking to use a servomotor to turn a acrylic platform, to adjust its angle whenever the inclination changes.
There're other feature as well. Might discuss them at another thread. :)
I have already bought ADXL335 from Cytron. Want to ask, do i need to get gryoscope and involve kaiman filter as well? Seen some tutorial at website that claim kaiman filter not necessary, as it's too complicated. :?
I'm using Pic18f452 and 20Mhz oscillator. And...i got not much knowledge and experience on programming.
But I found out a website. They share their source code. Was thinking to move on from there actually. Then saw this, and worry gyro and kaiman will have to come into the picture. @@
#include <p18f452.h>
#include <adc.h>
#include <stdlib.h>
#include <delays.h>
int result;
int flash;
void main(void)
         //Set Port B Output & Clear
TRISB = 0x00;
PORTB = 0x00;
         //Initialize The A/D Converter
OpenADC( ADC_FOSC_32
      & ADC_RIGHT_JUST
      & ADC_8ANA_0REF,
      ADC_CH0 & ADC_INT_OFF );
         //Flash At The Determined Rate
PORTB = 0x00;
Delay1KTCYx(flash);
PORTB = 0x01;
Delay1KTCYx(flash);
         //Get A/D Converted Value
Delay10TCYx(5);
ConvertADC();
while( BusyADC() );
   result = ReadADC();
            //If Within Normal Range Blink Slowly
if(result > 506 && result < 518)
   flash = 200;
            //If Slightly Tilted Blink Faster
if(result > 518 && result < 550)
   flash = 100;
if(result > 545 && result < 506)
   flash = 100;
            //If Really Tilted Blank FAST!
if(result >= 550)
   flash = 25;
if(result <= 450)
   flash = 25;
Any advice? :)
gilbertgan
Postby A380 » Fri Jan 14, 2011 6:27 pm
For Kalman filter code, this may help you.. http://www.rotomotion.com/downloads/tilt.c
It is free of charge.
A380
Postby SnowLeopard » Sat Jan 29, 2011 11:12 pm
Ok. Thank u very much. ^^
SnowLeopard
Re: Balancing Robot (schematic)
Postby ycwong » Thu Oct 20, 2011 2:10 pm
Hi!
May I know where can get the two wheel balacing schematic diagram that build by cytron.
ycwong
Return to ROBOT. Head to Toe Magazine
