A stupid stupid mistake. Help?
Fri Jun 18, 2010 8:41 pm
by Jiewy
Hie, um this is quite embarrassing but as i were soldering the compass module, the solder was too hot and the copper on the board came off, is there anyway i can send it to u guys for repair? If yes, how much would it be? The ic is still fine though.
Re: A stupid stupid mistake. Help?
Fri Jun 18, 2010 9:49 pm
by ober
Can you take a photo and post it here??
Sun Jun 20, 2010 10:54 am
by shiyan
is not stupid as long as you learn from the mistake that you have done. Anyway why did you solder the compass board itself? Why do you use header pin?? Luckily you are not soldering the component, it should be the breakout board, right?
Tue Jun 29, 2010 8:48 pm
by Jiewy
Well i did use header pin but then i realised that i needed to use jumper. so in the process of desoldering the header pin. this happened:-->
how do i add pics here?
Tue Jun 29, 2010 9:23 pm
by sich
You'll see this when you reply a post. Choose the file you want to upload and click "Add the file". The file will be attached to the post.
