Arduino Ethernet Shield
Postby shahrul » Thu Jul 28, 2011 11:42 pm
I see, that is easier to do Ethernet project and SD Card project using arduino. It have already the function for Ethernet and SD Card, not like Hi-Tech PIC. It save more time to learn.
Re: Arduino Ethernet Shield
Postby optitech » Sat Mar 17, 2012 11:36 pm
Can the Ethernet Shield working without Arduino UNO to ON/OFF the LED?
optitech
Postby sich » Sun Mar 18, 2012 4:23 pm
Unfortunately, NO. The shield by its own is just a TCPIP PHY module.
Postby fitri » Fri Apr 20, 2012 12:16 pm
do we need to setup pc as server? or arduino only :?:
fitri
Postby sich » Fri Apr 20, 2012 12:46 pm
fitri WROTE:do we need to setup pc as server? or arduino only
If you are using the Ethernet shield, you can use the Arduino server example code. Don't need a PC.
Postby fitri » Fri Apr 20, 2012 3:13 pm
good then..how about if the web require big memory due to got image in web server? usinf SD card can solve the problem? :?:
fitri
Postby sich » Sat Apr 21, 2012 3:47 am
Never try that but it should be fine. However, I don't think that's a good idea to create a complex webserver with Arduino alone. It's better to write simple html code to control the website or receive commands from the website on Arduino, then host the actual website with pictures and everything else on a server.
