Arduino + servo motor
Postby hansonlyz » Sun Apr 03, 2011 10:25 am
hi there, i got a few question i want to ask about. This is the first time i'm using arduino and have little exposure on PIC ucontroller also. I have tested PIC16F877A on SK40C to control a servo motor(C36R), it works fine. But when i try to work it with Arduino Duemilanove, the servo motor just jerks, and my arduino board keeps connect and disconnect from my computer. I still don't have clue on how to make this work.
basic idea of my mini project:
i'm trying to use a potentiometer to control the rotation of the servo motor. The following is my setup.
Setup:
1. Arduino Duemilanove connected to computer using USB cable, setup at COM3 port.
2. Servo motor (C36R): red cable > +5V on arduino board ; black cable > GND on arduino board ; white cable > pin2 on arduino board
3. Potentiometer: (when the knob is facing you), left connection > GND on arduino board ; centre connection > pin0 on arduino ; right connection > GND on arduino.
Codes:
int servoPin = 2;     // Control pin for servo motor
 int minPulse = 500;   // Minimum servo position
 int maxPulse = 2500;  // Maximum servo position
 int pulse = 0;        // Amount to pulse the servo
 long lastPulse = 0;    // the time in milliseconds of the last pulse
 int refreshTime = 20; // the time needed in between pulses
 int analogValue = 0;  // the value returned from the analog sensor
 int analogPin = 0;    // the analog pin that the sensor's on
 void setup() {
  pinMode(servoPin, OUTPUT);  // Set servo pin as an output pin
  pulse = minPulse;           // Set the motor position value to the minimum
 void loop() {
  analogValue = analogRead(analogPin);      // read the analog input
  pulse = map(analogValue,0,1023,minPulse,maxPulse);    // convert the analog value
                                                        // to a range between minPulse
                                                        // and maxPulse.
  // pulse the servo again if rhe refresh time (20 ms) have passed:
  if (millis() - lastPulse >= refreshTime) {
    digitalWrite(servoPin, HIGH);   // Turn the motor on
    delayMicroseconds(pulse);       // Length of the pulse sets the motor position
    digitalWrite(servoPin, LOW);    // Turn the motor off
    lastPulse = millis();           // save the time of the last pulse
It won't work. Servo motor just rotate slightly (a few degrees) and my Arduino board just disconnect and then re-connect, servo motor rotate slightly again and the process goes on.
Question:
1. since PIC16F877A on SK40C is working fine, is it because of the clock frequency that effects the result? SK40C is running max on 20MHz but Arduino Duemilanove only runs max 16MHz.
2. the servo motor draws too much current? but i'm only using one motor. This mini project i intent to use about 4 servo motor. Do i need to connect the servo motor to external power supply? if yes, how do i connect them?
Any help will be appreciated.
hansonlyz
Re: Arduino + servo motor
Postby sich » Mon Apr 04, 2011 1:21 pm
hansonlyz WROTE:But when i try to work it with Arduino Duemilanove, the servo motor just jerks, and my arduino board keeps connect and disconnect from my computer. I still don't have clue on how to make this work.
May be the voltage regulator on Arduino cannot supply enough current to your servo. Thus it resets the circuit due to voltage drop until lower than the Vmin for the mcu on board. You should supply the servo with an external power other than only through the USB connection.
hansonlyz WROTE:2. the servo motor draws too much current? but i'm only using one motor. This mini project i intent to use about 4 servo motor. Do i need to connect the servo motor to external power supply? if yes, how do i connect them?
Yes, you need external power supply. Please refer to PR18 Biped Walking Robot for the sample schematic.
Postby aly » Sun Feb 24, 2013 8:12 pm
guys,
in order for you to using servo motor from arduino board, do you have some extra connection i means using UART converter. is't without UART servo motor also able to run. because what i know, servo is half duplex and arduino by full duplex
aly
Postby robosang » Mon Feb 25, 2013 9:32 am
I think mistaken what is servo motor. This thread is talking about standard RC servo, you might be talking about serial control servo such as robotis's AX or Cytron's G15. So don mix up.
