error in programming..
Postby endung70 » Tue Apr 03, 2012 6:08 pm
last time i try to build arduino severino.. I use AVR usbasp programmer and i use program Arduino by using USBasp without bootloader. When i want to upload to i/o board,the program show error like this:
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
is that problem in my builded arduino or my coding?
please reply as soon as possible.. i only had 1 more week before submit project... :( :( :(
endung70
Re: error in programming..
Postby robosang » Thu Apr 05, 2012 11:24 am
Not familiar with the programmer, but my guess is hardware.
Postby hyng » Fri Apr 06, 2012 5:26 pm
First pls make sure your PC is able to detect the programmer. Have you install the driver already? Is the device manager showing the device?
Second, pls make sure the jumper label "Spd" is connected/shorted if you are using fresh Atmega chip.
There is some tutorial in AVR-USBASP product page, you can refer to it.
Users browsing this forum: No registered users and 61 guests
