if i'm not mistaken it means that you can also program the Atmel chip without the arduino board, as long as the ICSP connection is set up.
vick5821 WROTE:Okay, means that I can build my own arduino but then I changed the IC socket to 40pins ZIF socket so that it can be a programmer for AVR chip . Am I correct ?
Thank you
vick5821 WROTE:vick5821 WROTE:Okay, means that I can build my own arduino but then I changed the IC socket to 40pins ZIF socket so that it can be a programmer for AVR chip . Am I correct ?
Thank you
I make it as AVR programmer . But I need to burn bootloader to the AVR chip first ? Then only can upload code using Arduino IDE ?
How can I upload code to AVR chip like atmega 8 with no bootloader ? Do I need to make my own arduino ?
