IR sensor
IR sensor
Postby vick5821 » Sat Sep 15, 2012 3:06 pm
Based on this tutorial :
http://tutorial.cytron.com.my/2012/09/0 ... ir-sensor/
For the receiver, when it receive the IR sensor light the resistance value of itself will drop, on the other way when the IR receiver did not receive any IR the internal resistance value it high.
Is this the properties of the receiver ?
So, when the resistance value drop, the voltage will decrease, mean the resister on top of it accumulate more voltage in that region, so the LED will light on. It is the same at the other way round.
Why when accumulate more voltage it will light on the LED ? Higher difference in potential between the two point that cause the current to flow through the LED ? Am I correct ?
By the way, how if I plan to interface this with arduino UNO ?
Thank you
vick5821
Re: IR sensor
Postby yonghui » Mon Sep 17, 2012 7:53 pm
when the receiver is shined by IR, the resistance over the receiver drop. according to voltage divider law, the voltage across the receiver will drop also. this make the voltage across the resistor and LED rise, since the total voltage maintained same,5V. so the LED will light up.
for the circuit shown, with the LED, u can connect to arduino Analog pin and read the analog value. else u can add a comparator, LM324, or MCP601,MCP602 to convert it to digital value, and connect to digital pin of arduino.
Re: IR sensor
Postby vick5821 » Fri Sep 21, 2012 4:14 am
Okay. Get it. So this kind of receiver LED is different with 3 pins receiver phototransistor ? The working principle is different ?
vick5821
Re: IR sensor
Postby sich » Fri Sep 21, 2012 4:44 pm
Re: IR sensor
Postby yonghui » Sat Sep 22, 2012 2:03 pm
im not so sure which kind of phototransistor u mentioned. if its the type SiCH, then its a module which contains the filter, and the transmiter will need to modulate the signal will the frequency of the device.
another type with 3 legs, not much different, just that it has better gain.
which type u are using?
Re: IR sensor
Postby vick5821 » Sat Sep 22, 2012 7:20 pm
I bought this : http://www.cytron.com.my/viewProduct.ph ... trol%20Kit
Is this different from the 2 pin transmitter and receiver ?
vick5821
Re: IR sensor
Postby yonghui » Mon Sep 24, 2012 4:07 pm
oh, thats what mentioned by Sich.
so u can get the sample code of Arduino from the product page.
the remote sends modulated signal data out and the receive will receive the signal. and it has daylight filtering which eliminates noises of environment light
