Arduino Due
Arduino Due
Postby Brian Griffin » Thu Oct 04, 2012 9:47 pm
Another new Arduino which features Atmel's ATSAM3X8E with ARM Cortex-M3. It'll be launched at October 22. No floating point unlike the ARM Cortex-M4, but hey, it's still much easier to do something heavy with a 32-bit.
http://arduino.cc/forum/index.php?topic=125067.0
That Atmel ATSAM3X8E has a lot of guts inside, which is the hardware memory controller (not enough RAM? add some on it!), DAC (for all our projects which are musical in nature), SD-Card interface (no more need to write tough libraries for that anymore) and others like DMA.
I hope the IDE contains all the example libraries which utilizes the stuff inside. :)
Re: Arduino Due
Postby sich » Fri Oct 05, 2012 12:40 am
Anticipating its arriving in Cytron's store... ;)
Re: Arduino Due
Postby Brian Griffin » Fri Oct 05, 2012 10:43 am
The onboard DACs and the SD-Card controllers are what makes the new Arduino so attractive.
If these SD-Card controllers allow bootloaders, you know you can pop in a hex file inside the card and fire away the program. :)
