zhenning WROTE:Hi,
You can use arduino uno or arduino mega. You can buy the bluetooth module and attached to itThere are also wifi modules available
Idris WROTE:You can refer to Android to PIC via Bluetooth.
wanes WROTE:Hi... i would like using the arduino for FYP...
Can i used the Arduino Mega 2560 R3-Main Board can control the LED and shape memory alloy? The shape memory alloy is one material using the heated to active it.
wanes WROTE:HI,
Shape memory alloy is one accessions used to replace motor. Shape memory alloy is using the voltage to active it.
The arduino board can control shape memory alloy?
