Adruino + Xbee +motor
Postby HIIKIEWHUI » Fri Nov 09, 2012 8:30 pm
if i just wanna to control one motor by using the Xbee, is the arduino is needed?
Waiting for replying.Thanks
Regards.
HIIKIEWHUI
Re: Adruino + Xbee +motor
Postby zhenning » Sat Nov 10, 2012 3:53 pm
HIIKIEWHUI WROTE:Hi,
Regards.
At least a microcontroller is needed. Either arduino or a PIC or etc
zhenning
Postby robosang » Mon Nov 12, 2012 10:12 am
Yup! a microcontroller is need to process the data receive from XBee, forward, backward, speed, etc
Postby gadgetng » Tue Nov 13, 2012 1:51 pm
Regards.
If you don't want to use Arduino or any other microcontroller, how are you going to drive the motor from XBee? XBeee is just a wireless interface.
gadgetng
Postby ober » Wed Nov 14, 2012 9:17 am
Well, it depends 8-)
If it is simple control using push button and potentiometer for speed, that is possible without microcontroller, still you will need a motor driver.
XBee can be configured as standalone IO device, you can check one of our DIY project, PR20, XBee - Standalone Control and Monitoring, download the Detailed Description, it explains quite comprehensive about setting the Xbee.
