2 amp motor shield
PostPosted: Tue Nov 20, 2012 4:52 pm
by lumy85
If i want to use arduino power to drive the dc motor, is Adapter 12V 2A is suitable ?
PS: there is jumper to chose arduino power or external dc power supply.
Re: 2 amp motor shield
PostPosted: Tue Nov 20, 2012 5:14 pm
by zhenning
Did you read this:
User 2012-11-19 20:11:21
Can i use a Adapter 12V 2A for this product?Will it burn my arduino board?
Admin Reply :
Nop, Arduino main board does not take power from this shield. If you supply 12V to this motor shield for motor supply it is within voltage range 7V to 12V. If you supply the adapter to Arduino main board, it is still within range, 7V to 15V.
It also depends on your motor rating
PostPosted: Tue Nov 20, 2012 11:34 pm
by robosang
It depends on how much your motor draw. Arduino main board should have some kind of diode to protect the polarity, diode will have maximum current rating too. I don think the Arduino main board will damage, just that diode will be super hot if the current drawn by motor shield is at 2A. BTW, the adapter is also at max 2A, not really recommend taking 2A from the adapter.
