Bluebee + Skx BeeBoard
Postby fatinathirah » Fri Mar 08, 2013 10:32 am
Hi, Im having problem with the Bluebee + Skx BeeBoard that I bought. The thing is my laptop cannot detect the product. Acoording to http://tutorial.cytron.com.my/2011/08/1 ... h-bee/#3.0 Test your BTBEE using AT mode and http://tutorial.cytron.com.my/2012/07/2 ... h-bluebee/ the laptop should detect by itself. I need help like really urgent! please! its for my fyp. tq.
fatinathirah
Re: Bluebee + Skx BeeBoard
Postby robosang » Fri Mar 08, 2013 11:16 am
How is the hardware setup? Can share a photo?
Is the baudrate correct? Have the SKXBee driver being installed?
Postby fatinathirah » Fri Mar 08, 2013 3:51 pm
After connecting everything just like in the USB Starter Kit User Manual (http://www.cytron.com.my/usr_attachment ... Manual.pdf) , I download the USB driver from http://www.cytron.com.my/viewProduct.php?pcode=SKXBEE and extract it into my computer. According to FTDI Driver Installation guide (http://www.cytron.com.my/usr_attachment ... (FT_000093).pdf) page 6, it says that after unzip the driver file into the pc, then connect the usb port to pc, if the fevice is based on ft2232, the microsoft composite device will automatically loaded. Unfortunately that doesn't happen.
this how the hardware looks
fatinathirah
Postby robosang » Fri Mar 08, 2013 5:36 pm
I don think the driver will install automatically the 1st time. The window composite driver is just basic USB driver, the guide also stated that after the composite driver is loaded, the Found New Hardware wizard will appear.
Did you see any message pop up when you plug the USB in?
Do you see any USB Serial Port (COMx) under device manager?
Postby gadgetng » Sat Mar 09, 2013 11:19 am
ya, you need to install the driver manually.
gadgetng
Postby fatinathirah » Sun Mar 10, 2013 10:59 pm
yup2 it is in COM5. but when i plugged in, nothing pops up. how to solve it ya? im really confused right now.
fatinathirah
Postby fatinathirah » Sun Mar 10, 2013 11:04 pm
if the port can already be detected, doesn't that means the driver has already been installed? but there is no sign of Found New Hardware wizard appearing.
fatinathirah
Postby fatinathirah » Sun Mar 10, 2013 11:46 pm
Problem Solved~! My bluebee is working! btw thanks for ur help. If i encounter anymore problem, surely i'm going to ask u guys again. thanks a lot~!
fatinathirah
Postby robosang » Mon Mar 11, 2013 7:32 am
You should share what is the problem, so other can know and solve the problem . :mrgreen:
