by robosang » Fri Mar 08, 2013 5:36 pm
I don think the driver will install automatically the 1st time. The window composite driver is just basic USB driver, the guide also stated that after the composite driver is loaded, the Found New Hardware wizard will appear.
Did you see any message pop up when you plug the USB in?
Do you see any USB Serial Port (COMx) under device manager?
