Page 1 of 2
Arduino with Xbee Wifi Module Configuration
Sat Apr 27, 2013 10:52 pm
by rkosharil
I'll list my problem to make more easier understanding:
1. I have an arduino uno + Xbee wifi Shield + Xbee Wifi S6 Module
2. I tried to configure it with X-CTU Software and the software detect it
3. Then I scan for network in modem configuration. When I tried to connect to my network, this came out "Timeout Waiting to connect to selected access point".
What should I do?
Do I need to code something in the arduino?
It just won't connect.
Re: Arduino with Xbee Wifi Module Configuration
Sun Apr 28, 2013 10:45 am
by robosang
How is the setup? Can show a photo?
Sun Apr 28, 2013 1:17 pm
by rkosharil
Here is the picture of the problem I'm having :
Sun Apr 28, 2013 9:27 pm
by robosang
the hardware setup....
Mon Apr 29, 2013 12:12 am
by rkosharil
Ok Here is the picture:
Mon Apr 29, 2013 9:40 pm
by robosang
If you check the
XBee-WiFi Development Kit Getting Started Guide, page 13:Warning: The XBee Wi‐Fi module will not connect to access points or routers that use WEP or Enterprise security. The access point or router needs to be configured for DHCP
for the purposes of this guide.
Thu May 02, 2013 3:47 pm
by rkosharil
Just another question. Can I communicate with XBee WiFi without a router. Why do I need a router to communicate with xbee?
Thu May 02, 2013 9:43 pm
by robosang
Why don you try it?
Why need some one to tell you that? Try it and see. Search the Internet.
Thu May 02, 2013 9:54 pm
by rkosharil
Then what is the point asking people here in the forum if I have problem doing it??? What is this forum all about??? Chatting???
Fri May 03, 2013 9:00 am
by shahrul
rkosharil WROTE:Then what is the point asking people here in the forum if I have problem doing it??? What is this forum all about??? Chatting???
What the point you asking before doing? All people have their work and time. You do your work first, if problem then asking. Also, people answer if people have experience doing same thing. Not everybody doing same project.
