Lm35 and pulse sensor on Arduino (URGENT!!)NEED HELP
Postby zulikasahiera » Fri May 10, 2013 11:11 am
hi.. i want to read multiple sensors in arduino uno which are LM35 and pulse sensor.. i get my output already but unstable? i also done test the sensor oe by one. if the one sensor attach to arduino alone, it show right output but if i combine it together, the output become unstable..can anyone help me??
zulikasahiera
Re: Lm35 and pulse sensor on Arduino (URGENT!!)NEED HELP
Postby Jonathan Law » Fri May 10, 2013 11:51 am
zulikasahiera WROTE:hi.. i want to read multiple sensors in arduino uno which are LM35 and pulse sensor.. i get my output already but unstable? i also done test the sensor oe by one. if the one sensor attach to arduino alone, it show right output but if i combine it together, the output become unstable..can anyone help me??
can you please upload your hardware setup picture and coding here, then only we can find or suggest solution for your.
Jonathan Law
Postby robosang » Sat May 11, 2013 8:48 am
Yup, agreed, show us what you have done.
Postby zulikasahiera » Sat May 11, 2013 11:37 pm
this is my coding for combination of two sensors
>> Pulse Sensor Digital Filter <<
This code is the library prototype for Pulse Sensor by Yury Gitman and Joel Murphy
www.pulsesensor.com
>>> Pulse Sensor purple wire goes to Analog Pin 0 <<<
Pulse Sensor sample aquisition and processing happens in the background via Timer 1 interrupt. 1mS sample rate.
The following variables are automatically updated:
Pulse : boolean that is true when a heartbeat is sensed then false in time with pin13 LED going out.
Signal : int that holds the analog signal data straight from the sensor. updated every 1mS.
HRV : int that holds the time between the last two beats. 1mS resolution.
B : boolean that is made true whenever HRV is updated. User must reset.
BPM : int that holds the heart rate value. derived from averaging HRV every 10 pulses.
QS : boolean that is made true whenever BPM is updated. User must reset.
Scale : int that works abit like gain. use to change the amplitude of the digital filter output. useful range 12<>20 : high<>low default = 12
FSignal : int that holds the output of the digital filter/amplifier. updated every 1mS.
See the README for detailed information and known issues.
Code Version 0.6 by Joel Murphy December 2011 Happy New Year!
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
long Hxv[4]; // these arrays are used in the digital filter
long Hyv[4]; // H for highpass, L for lowpass
long Lxv[4];
long Lyv[4];
unsigned long readings; // used to help normalize the signal
unsigned long peakTime; // used to time the start of the heart pulse
unsigned long lastPeakTime = 0;// used to find the time between beats
volatile int Peak; // used to locate the highest point in positive phase of heart beat waveform
int rate; // used to help determine pulse rate
volatile int BPM; // used to hold the pulse rate
int offset = 0; // used to normalize the raw data
int sampleCounter; // used to determine pulse timing
int beatCounter = 1; // used to keep track of pulses
volatile int Signal; // holds the incoming raw data
int NSignal; // holds the normalized signal
volatile int FSignal; // holds result of the bandpass filter
volatile int HRV; // holds the time between beats
volatile int Scale = 13; // used to scale the result of the digital filter. range 12<>20 : high<>low amplification
volatile int Fade = 0;
boolean first = true; // reminds us to seed the filter on the first go
volatile boolean Pulse = false; // becomes true when there is a heart pulse
volatile boolean B = false; // becomes true when there is a heart pulse
volatile boolean QS = false; // becomes true when pulse rate is determined. every 20 pulses
int pulsePin = 0; // pulse sensor purple wire connected to analog pin 0
int tempPin = A3 ;
float temp ;
int counter = 0;
void setup(){
pinMode(13,OUTPUT); // pin 13 will blink to your heartbeat!
Serial.begin(115200);
lcd.begin(16, 2); // we agree to talk fast!
// this next bit will wind up in the library. it initializes Timer1 to throw an interrupt every 1mS.
TCCR1A = 0x00; // DISABLE OUTPUTS AND BREAK PWM ON DIGITAL PINS 9 & 10
TCCR1B = 0x11; // GO INTO 'PHASE AND FREQUENCY CORRECT' MODE, NO PRESCALER
TCCR1C = 0x00; // DON'T FORCE COMPARE
TIMSK1 = 0x01; // ENABLE OVERFLOW INTERRUPT (TOIE1)
ICR1 = 8000; // TRIGGER TIMER INTERRUPT EVERY 1mS
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void loop(){
temp = analogRead (tempPin);
temp = (((temp*5)/1024)*100) ;
//lcd.print (temp) ;
temp = temp;
Serial.println (temp) ;
if (counter <=1) {
lcd.setCursor (1,0) ;
lcd.print ("Temp:");
lcd.print (temp) ;
lcd.setCursor (0,1) ;
lcd.print (" BPM:");
lcd.print (BPM);
Serial.print ("T") ;
if (counter== 80) {
lcd.clear ();
counter = 0 ;
counter = counter++ ;
Serial.print("S"); // S tells processing that the following string is sensor data
Serial.println(Signal); // Signal holds the latest raw Pulse Sensor signal
if (B == true){ // B is true when arduino finds the heart beat
Serial.print("B"); // 'B' tells Processing the following string is HRV data (time between beats in mS)
Serial.println(HRV); // HRV holds the time between this pulse and the last pulse in mS
B = false; // reseting the QS for next time
if (QS == true){ // QS is true when arduino derives the heart rate by averaging HRV over 20 beats
Serial.print("Q"); // 'QS' tells Processing that the following string is heart rate data
Serial.println(BPM); // BPM holds the heart rate in beats per minute
QS = false; // reset the B for next time
Fade -= 15;
Fade = constrain(Fade,0,255);
//analogWrite(11,Fade);
delay(20); // take a break
// THIS IS THE TIMER 1 INTERRUPT SERVICE ROUTINE. IT WILL BE PUT INTO THE LIBRARY
ISR(TIMER1_OVF_vect){ // triggered every time Timer 1 overflows
// Timer 1 makes sure that we take a reading every milisecond
Signal = analogRead(pulsePin);
// First normailize the waveform around 0
readings += Signal; // take a running total
sampleCounter++; // we do this every milisecond. this timer is used as a clock
if ((sampleCounter %300) == 0){ // adjust as needed
offset = readings / 300; // average the running total
readings = 0; // reset running total
NSignal = Signal - offset; // normalizing here
// IF IT'S THE FIRST TIME THROUGH THE SKETCH, SEED THE FILTER WITH CURRENT DATA
if (first = true){
for (int i=0; i<4; i++){
Lxv[i] = Lyv[i] = NSignal <<10; // seed the lowpass filter
Hxv[i] = Hyv[i] = NSignal <<10; // seed the highpass filter
first = false; // only seed once please
// THIS IS THE BANDPAS FILTER. GENERATED AT www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html
// BUTTERWORTH LOWPASS ORDER = 3; SAMPLERATE = 1mS; CORNER = 5Hz
Lxv[0] = Lxv[1];
Lxv[1] = Lxv[2];
Lxv[2] = Lxv[3];
Lxv[3] = NSignal<<10; // insert the normalized data into the lowpass filter
Lyv[0] = Lyv[1];
Lyv[1] = Lyv[2];
Lyv[2] = Lyv[3];
Lyv[3] = (Lxv[0] + Lxv[3]) + 3 * (Lxv[1] + Lxv[2])
+ (3846 * Lyv[0]) + (-11781 * Lyv[1]) + (12031 * Lyv[2]);
// Butterworth; Highpass; Order = 3; Sample Rate = 1mS; Corner = .8Hz
Hxv[0] = Hxv[1];
Hxv[1] = Hxv[2];
Hxv[2] = Hxv[3];
Hxv[3] = Lyv[3] / 4116; // insert lowpass result into highpass filter
Hyv[0] = Hyv[1];
Hyv[1] = Hyv[2];
Hyv[2] = Hyv[3];
Hyv[3] = (Hxv[3]-Hxv[0]) + 3 * (Hxv[1] - Hxv[2])
+ (8110 * Hyv[0]) + (-12206 * Hyv[1]) + (12031 * Hyv[2]);
FSignal = Hyv[3] >> Scale; // result of highpass shift-scaled
//PLAY AROUND WITH THE SHIFT VALUE TO SCALE THE OUTPUT ~12 <> ~20 = High <> Low Amplification.
if (FSignal >= Peak && Pulse == false){ // heart beat causes ADC readings to surge down in value.
Peak = FSignal; // finding the moment when the downward pulse starts
peakTime = sampleCounter; // recodrd the time to derive HRV.
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
if ((sampleCounter %20) == 0){// only look for the beat every 20mS. This clears out alot of high frequency noise.
if (FSignal < 0 && Pulse == false){ // signal surges down in value every time there is a pulse
Pulse = true; // Pulse will stay true as long as pulse signal < 0
digitalWrite(13,HIGH); // pin 13 will stay high as long as pulse signal < 0
Fade = 255; // set the fade value to highest for fading LED on pin 11 (optional)
HRV = peakTime - lastPeakTime; // measure time between beats
lastPeakTime = peakTime; // keep track of time for next pulse
B = true; // set the Quantified Self flag when HRV gets updated. NOT cleared inside this ISR
rate += HRV; // add to the running total of HRV used to determine heart rate
beatCounter++; // beatCounter times when to calculate bpm by averaging the beat time values
if (beatCounter == 10){ // derive heart rate every 10 beats. adjust as needed
rate /= beatCounter; // averaging time between beats
BPM = 60000/rate; // how many beats can fit into a minute?
beatCounter = 0; // reset counter
rate = 0; // reset running total
QS = true; // set Beat flag when BPM gets updated. NOT cleared inside this ISR
if (FSignal > 0 && Pulse == true){ // when the values are going up, it's the time between beats
digitalWrite(13,LOW); // so turn off the pin 13 LED
Pulse = false; // reset these variables so we can do it again!
Peak = 0; //
}// end isr
i get two output.. but the output unstable... what should i do? is it something about ADC cannot read simultaneously?
zulikasahiera
Postby sich » Tue May 14, 2013 10:52 am
I guess the problem is caused by multiple analog conversions request at a time. The Pulse Sensor library code uses Timer 1 interrupt to read pin A0 analog value every milisec. Then you create another analogRead for pin A3 in the loop(). When the main program is reading A3 value, the conversion is interrupted by Timer 1 which starts reading A0 value.
Only one analog pin can be read at a time because there's only one ADC logic in the microcontroller and all analog input pins are MUXed. Please refer Atmel's App Note.
Postby zulikasahiera » Thu May 16, 2013 12:45 am
sich WROTE:I guess the problem is caused by multiple analog conversions request at a time. The Pulse Sensor library code uses Timer 1 interrupt to read pin A0 analog value every milisec. Then you create another analogRead for pin A3 in the loop(). When the main program is reading A3 value, the conversion is interrupted by Timer 1 which starts reading A0 value.
so, i sdould add ADMUX there? since i'm new bie in this area can u show me how? or give me some guidance or reference to do?
zulikasahiera
