Hello,
I have a problem using skps with arduino uno. I have test the skps using usb to uart converter and it give a result in hyperterminal. This means my skps and PS2 controller is fuctional and working. I test my arduino uno with serial connection using usb the default 0 and 1 pin. The input is from serial monitor in the arduino interface and it give no problem.
The problem came when I connect SKPS and UNO. The input from PS2 controller cannot be read by UNO because there are no response when I press any button on PS2 controller. I have try all code from the tutroial and in this forum and it still cannot work.
1) I disconnect the RX and TX pin before uploading so the code can upload correctly.
2) I use the serial software library to use digital pin as virtual serial connection to test wether pin 0 and 1 have a problem and it still cannot work.
3) RX and TX led didn't blink when connect SKPS and UNO but it will blink when I use the serial monitor in Arduino.
I have try all step and method that been suggested and it still cannot work. Do anybody have a problem same like me or just my UNO board that malfunction?
