My first Mini Pro, Atmega328 5v16M, Won't upload
Postby Edward » Sun Jul 07, 2013 1:02 am
I'm trying to get my first Mini Pro Atmega328 5v 16M module to operate, but I seem to be having a loading failure.
The power LED is on, and the Pin 13 LED is blinking, with the Blink sketch pre-installed I assume.
I'm receiving the "avrdude: stk500_getsync(): not in sync: resp=0x00" error and no load.
I have verified my serial port's operation via loop test, and tried other mini pro models under Board select.
I've tried 9600 baud, same as used with a working Nano Atmega328 5v 16M module I have, and 38400, no change.
I have connecting everything per these instructions: http://tutorial.cytron.com.my/2012/02/28/loading-program-to-arduino-promini/, but it didn't help.
Any suggestions appreciated.
Edward
Re: My first Mini Pro, Atmega328 5v16M, Won't upload
Postby robosang » Sun Jul 07, 2013 5:18 pm
Photos of the actual connection should be helpful.
Postby sich » Fri Jul 12, 2013 11:11 am
Edward WROTE:I'm receiving the "avrdude: stk500_getsync(): not in sync: resp=0x00" error and no load.
My experience when I got this error:
1. USB cable-connector connection
2. Wrong selection of Serial port and Board
3. If I connected some circuit to the UART pin of the board while uploading
4. shorted/dirty FT232 leads or Arduino UART pins
Usually this solve the problem. Otherwise you may have a faulty FT232.
