Output is 8 output each time
Postby Hidayah » Thu Nov 28, 2013 7:22 pm
hye there... im used ph sensor and arduino uno...
why my result is display at LCd and serial monitor is 8 ph value each time? like picture below...and the ph print that should appear is not appear at
and here is coding that i used...thanks...
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
#include <SoftwareSerial.h>                                                    //add the soft serial libray
#define rxpin 2                                                              //set the RX pin to pin 2
#define txpin 3                                                              //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin);                                         //enable the soft serial port
String inputstring = "";                                                       //a string to hold incoming data from the PC
String sensorstring = "";                                                      //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false;                                          //have we received all the data from the PC
boolean sensor_stringcomplete = false;                                         //have we received all the data from the Atlas Scientific product
  void setup(){        //set up the hardware
     Serial.begin(38400);                                                      //set baud rate for the hardware serial port to 38400
     myserial.begin(38400);                                                    //set baud rate for software serial port to 38400
     inputstring.reserve(1);                                                   //set aside some bytes for receiving data from the PC
     sensorstring.reserve(1);      //set aside some bytes for receiving data from Atlas Scientific product
     lcd.begin(16, 2);
     lcd.println("Ph : ");
   void serialEvent() {                                                         //if the hardware serial port receives a char
               char inchar = (char)Serial.read();                               //get the char we just received
               inputstring += inchar;                                           //add it to the inputString
               if(inchar == '\r') {input_stringcomplete = true;}                //if the incoming character is a <CR>, set the flag
 void loop(){        //here we go....
  if (input_stringcomplete){                                                   //if a string from the PC has been recived in its entierty
      myserial.print(inputstring);                                             //send that string to the Atlas Scientific product
      lcd.println(inputstring);                                                  //
      inputstring = "";                                                        //clear the string:
      input_stringcomplete = false;                                            //reset the flage used to tell if we have recived a completed string from the PC
  while (myserial.available()) {                                               //while a char is holding in the serial buffer
         char inchar = (char)myserial.read();                                  //get the new char
         sensorstring += inchar;                                               //add it to the sensorString
         if (inchar == '\r') {sensor_stringcomplete = true;}                   //if the incoming character is a <CR>, set the flag
   if (sensor_stringcomplete){                                                 //if a string from the Atlas Scientific product has been received in its entirety
       Serial.print(sensorstring);        //use the hardware serial port to send that data to the PC sensorstring = "";
      lcd.setCursor(0, 1);
      lcd.println(sensorstring);        //print the current status of the pH into the LCD                                                             //clear the string:
       sensorstring = "";
       sensor_stringcomplete = false;                                         //reset the flag
      delay(10000);   // Wait about 10 seconds to display
Hidayah
Re: Output is 8 output each time
Postby atuk5259 » Mon Dec 16, 2013 5:17 pm
1-Ph sensor come with storage liquid (small bottle).. are u remove the buffer liquid and test at actual or buffer liquid (calibration liquid) ?...
2-Your sensor reading is 6.XX....not 8.XX.
3-pls caibrate your sensor to get actual reading..(refer datasheet)
atuk5259
Postby shahrul » Mon Dec 16, 2013 6:56 pm
You can test with provided fluid with ph 4, 7 and 10. There is also can calibrate with the test fluid.
