Output is 8 output each time
hye there... im used ph sensor and arduino uno...
why my result is display at LCd and serial monitor is 8 ph value each time? like picture below...and the ph print that should appear is not appear at
and here is coding that i used...thanks...
- CODE: SELECT_ALL_CODE
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
#include <SoftwareSerial.h> //add the soft serial libray
#define rxpin 2 //set the RX pin to pin 2
#define txpin 3 //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin); //enable the soft serial port
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
void setup(){ //set up the hardware
Serial.begin(38400); //set baud rate for the hardware serial port to 38400
myserial.begin(38400); //set baud rate for software serial port to 38400
inputstring.reserve(1); //set aside some bytes for receiving data from the PC
sensorstring.reserve(1); //set aside some bytes for receiving data from Atlas Scientific product
lcd.begin(16, 2);
lcd.println("Ph : ");
void serialEvent() { //if the hardware serial port receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if(inchar == '\r') {input_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
void loop(){ //here we go....
if (input_stringcomplete){ //if a string from the PC has been recived in its entierty
myserial.print(inputstring); //send that string to the Atlas Scientific product
lcd.println(inputstring); //
inputstring = ""; //clear the string:
input_stringcomplete = false; //reset the flage used to tell if we have recived a completed string from the PC
while (myserial.available()) { //while a char is holding in the serial buffer
char inchar = (char)myserial.read(); //get the new char
sensorstring += inchar; //add it to the sensorString
if (inchar == '\r') {sensor_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
if (sensor_stringcomplete){ //if a string from the Atlas Scientific product has been received in its entirety
Serial.print(sensorstring); //use the hardware serial port to send that data to the PC sensorstring = "";
lcd.setCursor(0, 1);
lcd.println(sensorstring); //print the current status of the pH into the LCD //clear the string:
sensorstring = "";
sensor_stringcomplete = false; //reset the flag
delay(10000); // Wait about 10 seconds to display
