Problem with SHIELD-PS2 arduino and servo
Postby malikai » Sun Dec 29, 2013 10:08 pm
Recently I have bought the ps2 sheild..I just simply want to use it for moving a servo using ps2 library that given..
But the servo wont stop move on it's own even when there is no signal from ps2 controller..I think it's some kind of noise
I would like to know if there is a way to solve this problem..This is the sketch
#include <Servo.h>
#include <Shield_PS2.h>
PS2 ps2=PS2();
Servo myservo;
myservo.attach(9);
   ps2.init(9600, 2, 3);
  if( ps2.getval(p_left)==0)
myservo.writeMicroseconds (1100);
delay (10);
    if( ps2.getval(p_up)==0)
myservo.writeMicroseconds (1600);
delay (10);
      if( ps2.getval(p_right)==0)
 myservo.writeMicroseconds (2300);
delay (10);
malikai
Re: Problem with SHIELD-PS2 arduino and servo
Postby ober » Thu Jan 02, 2014 8:45 am
Are you using external power source to power the Arduino and everything? Unstable RC servo behavior might due to insufficient power.
Try writing program for the servo only, and later add in PS2 shield program.
Postby malikai » Sat Jan 04, 2014 1:29 pm
Yes I connect it to external power..But if I just use the remote stand alone to send high/low bit..There is no problem at all
Here's the sample code when I connect it to the remote
#include <Servo.h>
PS2 ps2=PS2();
Servo servox;
Servo servoy;
int vcw=1;
int vccw=1;
int hcw=1;
int hccw=1;
int posx=0;
int posy=0;
pinMode(2, INPUT);
pinMode(4, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
servox.attach(9);
servoy.attach(11);
hccw=digitalRead(7);
hcw=digitalRead(6);
vccw=digitalRead(2);
vcw=digitalRead(4);
posx=constrain(posx,0,180);
posy=constrain(posy,0,180);
if(vccw==0 && vcw==1)
posy++;
servoy.write(posy);
delay(10);
if(vcw==0 && vccw==1)
posy--;
servoy.write(posy);
delay(10);
if(hccw==0)
posx++;
servox.write(posx);
delay(10);
if(hcw==0)
posx--;
servox.write(posx);
delay(10);
malikai
Postby ober » Sun Jan 05, 2014 7:04 am
Looking through your code again trigger some thought, now I understand the possible root cause. This is due to interrupt.
Servo library uses interrupt to output pulses further control the RC servo, while softserial also uses interrupt to transmit and receive UART. Softserial will disable the interrupt for a short period of time and this affect the Servo function to generate proper pulses and drive the RC servo.
There are plenty of discussion in the Internet, example: http://forum.arduino.cc/index.php/topic,28456.0.html
One easy method you can try is to use hardware UART (D0 and D1) for PS2 shield. Anyway this will affect the bootloader process as pin 0 and pin 1 is being used for program loading, just disconnect the jumper D0 when you expect to load program and place it back after done uploading program. Do not use softserial.
