#include <G15.h> // include the library
#define LED_BOARD 13
/*Return Error definitions & Mask
=====Higher 8 bits of Word=========
packet length error : 0x0100
packet header error: 0x0200
ID mismatch error: 0x0400
packet checksum mismatch : 0x0800
====Lower 8 bits of word==========
Error status return by G15:
INST 0x0040
OVERLOAD 0x0020
CHECKSUM 0x0010
RANGE 0x0008
OVERHEAT 0x0004
ANGLELIMIT 0x0002
VOLTAGE 0x0001
//declaration of variables & object
word ERROR=0;
byte DATA[10];
word STATUS;
//declare G15 Class Object
//servo1 ID=1
AX12 servo1(1);
//servo2 ID=2
AX12 servo2(2);
void setup(){
//initialize the arduino main board's serial/UART and Control Pins
G15ShieldInit(19200,3,8);
//call the init function to init servo obj
servo1.init();
servo2.init();
//init LED indicator as output
pinMode(LED_BOARD,OUTPUT);
digitalWrite(LED_BOARD, LOW);
delay(500);
digitalWrite(LED_BOARD, HIGH);
void loop(){
servo1.SetLED(ON,iWRITE_DATA);
servo1.SetSpeed(500,iWRITE_DATA);
servo1.SetPos(ConvertAngle2Pos(0),iWRITE_DATA); //goto 0 degree pos
delay(1000);
servo1.SetPos(ConvertAngle2Pos(90),iWRITE_DATA); //goto 90 degree pos
servo1.SetSpeed(250,iWRITE_DATA);
servo1.SetLED(OFF,iWRITE_DATA);
delay(1000);
servo2.SetLED(ON,iWRITE_DATA);
servo2.SetSpeed(250,iWRITE_DATA);
servo2.SetPos(ConvertAngle2Pos(0),iWRITE_DATA); //goto 0 degree pos
delay(1000);
servo2.SetSpeed(500,iWRITE_DATA);
servo2.SetPos(ConvertAngle2Pos(90),iWRITE_DATA); //goto 90 degree pos
servo2.SetLED(OFF,iWRITE_DATA);
delay(1000);
