Grove Water Sensor
Grove Water Sensor
Postby wowwowwen » Thu Apr 24, 2014 9:54 pm
http://www.seeedstudio.com/wiki/index.p ... ter_Sensor
http://www.cytron.com.my/viewProduct.ph ... r%20Sensor
Hey guys, I am currently doing a project with a water sensor and using Arduino Uno as the controller.
From the forum, I found only example of using the pin as digital input.
Is there any example of using the analog input? Thank you.
wowwowwen
Re: Grove Water Sensor
Postby Idris » Mon Apr 28, 2014 10:32 am
Hi wowwowwen,
You can refer here too http://arduino.cc/en/Tutorial/AnalogInput.
