G15 servo Motion Quality
I'm trying to use my G15 to build a panning tripod head, I've set it up no problem but the motion quality is very jerky or keeps stop/starting and then jumping forward at low speeds. I've tried wheel mode and normal positioning but the problem persists for speeds of (say) 5, I've also tried all 4 G15 units I have with the same result.
http://www.youtube.com/watch?v=7oQTZjw0iuk
Is there a servo motor assembly that you stock that you would recommend that has speed and direction control and very good motion quality? I'm very reluctant to end up using geared down stepper motors for this application due to the size and weight.
Thanks,
John.
Thanks,
John.
