edit
edit
Postby wadafakbbq » Thu Sep 25, 2014 12:22 am
edit
wadafakbbq
Re: Uno interface with SD Card
Postby ober » Thu Sep 25, 2014 8:59 am
Download the latest library and examples sketch from the product page and try again.
We have just updated it.
Postby wadafakbbq » Thu Sep 25, 2014 11:17 pm
ober WROTE:Download the latest library and examples sketch from the product page and try again.
Ok Thanks, with the new library i manage to upload code to arduino without any problem
wadafakbbq
Re: Uno interface with Fingerprint module UART
Postby wadafakbbq » Sat Sep 27, 2014 1:24 am
New problem, saving the space by editing the old thread. Would appreciate if anyone would help.
wadafakbbq
Postby ober » Sat Sep 27, 2014 8:27 pm
wadafakbbq WROTE:I was trying to trying to interface my fingerprint module with a. uno, tried to make direct connection and access via fingerprint software provided by cytron, i was able to make it work. I don't know whats the problem but a.uno kept giving me "no fingerprint sensor found" when tried to access via a. uno. I recheck the connection couples of time and tried changing it to other port still the same result. I'm using library thats provided by adafruit, my RX pin on #2 while TX pin on #3. Oh, I already tried changing the baud rate, nada.
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  Serial.println("fingertest");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
  } else {
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
void loop()                     // run over and over again
  Serial.println("Type in the ID # you want to save this finger as...");
  uint8_t id = 0;
  while (true) {
    while (! Serial.available());
    char c = Serial.read();
    if (! isdigit(c)) break;
    id *= 10;
    id += c - '0';
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
  uint8_t p = -1;
  Serial.println("Waiting for valid finger to enroll");
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
      break;
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
      break;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      break;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      break;
    default:
      Serial.println("Unknown error");
      break;
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
      break;
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      break;
      Serial.print(".");
      break;
      break;
      break;
    default:
      break;
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      break;
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
  } else {
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
  } else {
    return p;
Hi, please open another topic as it is very confusing, the title and the reply by other are not the same.
