ober WROTE:Download the latest library and examples sketch from the product page and try again.
We have just updated it.
wadafakbbq WROTE:I was trying to trying to interface my fingerprint module with a. uno, tried to make direct connection and access via fingerprint software provided by cytron, i was able to make it work. I don't know whats the problem but a.uno kept giving me "no fingerprint sensor found" when tried to access via a. uno. I recheck the connection couples of time and tried changing it to other port still the same result. I'm using library thats provided by adafruit, my RX pin on #2 while TX pin on #3. Oh, I already tried changing the baud rate, nada.
- CODE: SELECT_ALL_CODE
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
void loop() // run over and over again
Serial.println("Type in the ID # you want to save this finger as...");
uint8_t id = 0;
while (true) {
while (! Serial.available());
char c = Serial.read();
if (! isdigit(c)) break;
id *= 10;
id += c - '0';
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
Serial.println(".");
break;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
break;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
break;
default:
Serial.println("Unknown error");
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
Serial.println("Place same finger again");
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
} else {
return p;
Users browsing this forum: No registered users and 63 guests
