Uno interface with Fingerprint module UART
Postby wadafakbbq » Sun Sep 28, 2014 2:03 pm
I was trying to trying to interface my fingerprint module with a. uno, tried to make direct connection and access via fingerprint software provided by cytron, i was able to make it work. I don't know whats the problem but a.uno kept giving me "no fingerprint sensor found" when tried to access via a. uno. I recheck the connection couples of time and tried changing it to other port still the same result. I'm using library thats provided by adafruit, my RX pin on #2 while TX pin on #3. Oh, I already tried changing the baud rate, nada.
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  Serial.println("fingertest");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
  } else {
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
void loop()                     // run over and over again
  Serial.println("Type in the ID # you want to save this finger as...");
  uint8_t id = 0;
  while (true) {
    while (! Serial.available());
    char c = Serial.read();
    if (! isdigit(c)) break;
    id *= 10;
    id += c - '0';
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
  uint8_t p = -1;
  Serial.println("Waiting for valid finger to enroll");
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
      break;
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
      break;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      break;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      break;
    default:
      Serial.println("Unknown error");
      break;
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
      break;
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      break;
      Serial.print(".");
      break;
      break;
      break;
    default:
      break;
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      break;
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
  } else {
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
  } else {
    return p;
wadafakbbq
Re: Uno interface with Fingerprint module UART
Postby ober » Sun Sep 28, 2014 8:34 pm
So the fingerprint module is working, but with example sketch/library from adafruit it is not working? Is the library from adafruit compatible with the fingerprint module?
Postby wadafakbbq » Mon Sep 29, 2014 5:16 am
ober WROTE:So the fingerprint module is working, but with example sketch/library from adafruit it is not working? Is the library from adafruit compatible with the fingerprint module?
I guess not, the ada fruit version are similar to SM fp version. If anyhow you could provide the library for the cytron fingerprint?
wadafakbbq
Postby ober » Mon Sep 29, 2014 8:40 am
currently we have yet to come out with the Arduino library for this fingerprint scanner. But you are welcome to refer to DIY project PR29: http://www.cytron.com.my/viewProduct.php?pid=DAEcFhANDA8tGDceHQ4dINvlbEFEQ7y. The sample source code "talks" to the fingerprint scanner. Even it is base on PIC, but the example code is open and you are free to modify it to Arduino sketch.
Do share with us your result.
