Problem with arduino uno + PS2 shield
Postby proton_gt » Fri Oct 03, 2014 4:02 pm
hi all.
i have problem with my source code.
//Panning control
    int panchange = 2;
    if( ps2.getval(p_triangle)==0)      //Triangle button is pressed
    panpos = panpos + panchange;
    if( ps2.getval(p_cross)==0)         //Cross button is pressed
    panpos = panpos - panchange;
  panpos = constrain (panpos, 0, 180); //limit of value tilt position
  panservo.write(panpos);
  delay(500);
  //Tilting control
    int tiltchange = 2;
    if( ps2.getval(p_circle)==0)         //Circle button is pressed
    tiltpos = tiltpos + tiltchange;
    if( ps2.getval(p_square)==0)         //Square button is pressed
    tiltpos = tiltpos - tiltchange;
  tiltpos = constrain (tiltpos, 0, 180); //limit of value tilt position
  tiltservo.write(tiltpos);
  delay(200);
    if( ps2.getval(p_r1)==0)             //R1 button is pressed
    tiltservo.write(90);                 //tilting home positioning
    panservo.write(90);                  //panning home positioning
    delay(200);
some the code for getval(p_xxx) will change into blue font in IDE, but some code will stay black font.
the problem is when I upload the program, the button that change into blue font will problem when program running but the button that stay in black font ok.
in this sketch, triangle, circle and square will change into blue font but others stay in black font. is that will effect the program?? what is the mistake with my program??
proton_gt
Re: Problem with arduino uno + PS2 shield
Postby yonghui » Tue Oct 07, 2014 10:55 am
can you try to troubleshoot the condition?
try to light on LED of arduino UNO when the triangle, circle or square is pressed. if the LED can light on without any problem, then the problem comes from the remaining code. I cant understand what is the running program problem meant by you. mayb you will need explain more.
