Interfacing Bluebee with PC
Postby sssk30 » Sat Mar 21, 2015 1:25 pm
Hi there, I am making a wireless and portable gait monitoring system using bluetooth as its main communication method. The bluebee would be placed on the transmitter end while the PC would be using reading the results from its build-in bluetooth.
Components for Transmitter end
1) SN-IMU5D-LC
2) SKXBee
3) Bluebee
4) BBfuino
Using these components, is it possible for me to read and capture value from the serial port itself?
As for wired connection to my laptop I am able to capture and save serial port value using coolterm.
sssk30
Re: Interfacing Bluebee with PC
Postby Idris » Mon Mar 23, 2015 9:32 am
Hi sssk30.
Yes, it is possible. Once you paired the bluetooth, you should get the bluetooth COM port.
Postby sssk30 » Tue Mar 24, 2015 4:59 am
I followed the example from this link http://tutorial.cytron.com.my/2014/05/07/uploading-arduino-sketch-to-bbfuino-via-bluebee/ however, I am not able to get the bluebee device to work.
When i plug in my SKXBee to my laptop, this is what i see Image
It comes in as other devices. Is there a way to change this?
sssk30
Postby ober » Tue Mar 24, 2015 1:47 pm
It seem you did not install the USB driver for SKXBee, please refer to the User's Manual of SKXBee.
Users browsing this forum: No registered users and 62 guests
