by jibby93 » Mon Mar 30, 2015 5:12 pm
Okay..now i think I get it.. one more question...refer to this tutorial :http://tutorial.cytron.com.my/2012/12/03/getting-started-with-arduino-fio/ , did I need to do modification on my skxbee ? it mentioned that :
"You will need to do some modification on the SKXBee to enable wireless bootloading J.Take the SKXBee Rev2.0, look carefully, at the right side of XBee module, there are 2 pads labeled as DTR and DIO3, short it using solder lead."
Since I cannot load program using RFbee did I need to solder the pads(DTR and DI03) ?
