Arduino to RS232 interface issue
Postby eujin888 » Fri Feb 05, 2016 8:51 pm
I am trying to interface an arduino mega via a level converter to a RS232 device. To activate the RS232 device, I found I have to send string of hex codes. When I send the codes direct from the PC to the RS232 device, I see data being read back. But when I send the codes from the arduino/level converter, the RS232 device sends nothing to the arduino serial monitor.
Codes sent to RS232 device:
0x55,0xAA,0x01,0x00,0x00,0x00,0x00,0x01,0x00
I expect the RS232 device to respond:
55 AA 01 00 00 00 25 00 01 00 01 00 5E 00 5E 00 00 00 00 00 00 00 22 00 22 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 49
The arduino program I used:
#include <SoftwareSerial.h>
int i = 0;
int x = 1 ;
byte GetData[] = {0x55,0xAA,0x01,0x00,0x00,0x00,0x00,0x01,0x00};
void setup() {
 if(x>0){
   for (int i=0; i<sizeof(GetData); i++){
     Serial.write(GetData[i]);
        x=x-1;
 if (Serial.available()) {
   Serial.println("data");
   while(Serial.available()>0) {
     byte inByte = Serial.read();
     //Serial.print(inByte);
     delay(10);
The arduino serial monitor is blank.
Please help. Is there some bugs in my arduino program, or I have wrong configuration.
Thank you.
eujin888
Re: Arduino to RS232 interface issue
Postby bengchet » Mon Feb 15, 2016 9:57 am
From your coding, you have commented the line
Of course it won't show the output on Serial monitor.
Plus, to show the data in Hex form, use
Serial.print(inByte, HEX);
If still haven't got any satisfying result, it might be hardware setup problem.
