+5 to VIN and uc00a
+5 to VIN and uc00a
Postby tfcbacct » Tue Jul 26, 2016 12:39 am
I have a ESPRESSO-LITE-2.0 powered by permanent +5V power supply connected to VIN. When I connect the uc00a the Espresso appears to reboot (based on the DS-OLED-MOD showing the espert logo and then the expected text).
1. Is there any way to prevent this?
2. Does this cause damage to the uc00a or Espresso?
Thanks!
tfcbacct
Re: +5 to VIN and uc00a
Postby bengchet » Tue Jul 26, 2016 2:48 pm
Does it keep reboot or just reboot once when you plug in UC00A to Espresso Lite v2.0 powered with permanent external power supply +5V?
For your case you can try just bend the VIN pin from 6 pin header on Espresso Lite v2 board, so UC00A just connects 5 pins other than VIN, UC00A will not supply +5V to VIN.
