Re: ESP8266 with Cytron UNO DHCP failed
Posted: Sat Oct 08, 2016 1:52 am
From the error log you have shown, your path to the BlynkiESP8266 library seems also incorrect.
/Users/Mac/Documents/Arduino/libraries/BlynkESP8266_Lib/BlynkApiArduino.h
Inside /Users/Mac/Documents/Arduino/libraries/BlynkESP8266_Lib, there should not be a file called BlynkApiArduino.h included in that folder.
My suggestion is,
1) Check if in /Users/Mac/Documents/Arduino/libraries, there is a folder called Blynk, inside should be including many folders and files, and one of them is BlynkApiArduino.h file. That folder is for Blynk main library. You should be able to see it because you have downloaded it from library manager recently.
2) Delete BlynkESP8266_Lib folder currently you have, download the file attached on previous posts and extract it to /Users/Mac/Documents/Arduino/libraries, same directory as where Blynk folder is placed. Inside the folder there should be only 4 files, ESP8266.cpp, ESP8266_Lib.h, keyword.txt and readme.md.
My suggestion is,
