Cytron ESPWiFi Shield with Blynk
I'm currently doing Blynk IoT project which we can control from Smartphone to the SHIELD-ESP-WIFI ESP8266 with CYTRON UNO. My ESP WIFI already connected to the Wifi, which I check through the AT+CIFSR command in Serial Monitor. It just a simple Blynk project, to turn ON and OFF the LED. However the problem I face is DHCP failed. Really appreciate if you can give me the solution, already look in other forum, but still not solved. Thanks.
