Problem in uploading code when I use micro USB jack
Postby HS LIM » Wed Nov 02, 2016 7:06 pm
Hi, previously I program my cytron uno board with progisp through usbasp and I accidentally tick program fuse. I not sure whether is this the action that causes the problem now. I can't program my cytron uno board with USB jack anymore as it shows me the error messages below. Can anyone help me? :cry: :cry: Thanks.
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,066 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc8
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
HS LIM
Re: Problem in uploading code when I use micro USB jack
Postby bengchet » Thu Nov 03, 2016 8:17 am
You might have erased the UART bootloader. Try upload the bootloader first before uploading user program with micro USB.
Hope it helps!
Postby HS LIM » Thu Nov 03, 2016 10:10 am
I tried to burn the bootloader but it shows me this error message, please help :cry: :cry: ...
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbasp
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
avrdude done. Thank you.
Error while burning bootloader.
HS LIM
Postby HS LIM » Thu Nov 03, 2016 10:16 am
I tried to burn the bootloader with usbasp and it works!!! :D :D :D Thanks for your help!!
HS LIM
