G15 Driver GD02 R2.0
Postby Ravinath » Sun Nov 19, 2017 7:48 pm
Hye. Im trying to run a G15 servo motor using GD02 R2.0 driver and arduino. but Im unable to make it run.im using Cytron-G15Shield-master library.can anyone help me??thanks
hye..im trying to run a G12 cube servo using Gd01 rev2.0 driver. when i upload the g15 library the motor is not functioning. connections i made:
G15DriverInit(19200,2,3,8);
arduino rx(2) --------connected to GD02 tx
arduino tx(3)---------connected to GD02 rx
arduino pin(8)--------connected to GD02 CTRL
thanks..
Ravinath
Re: G15 Driver GD02 R2.0
Postby Idris » Mon Nov 20, 2017 11:18 am
Hi Ravinath,
Could you share a few clear photos of your hardware setup?
Note: I have combine your previous post to this post.
Postby Ravinath » Thu Nov 30, 2017 6:37 pm
Idris WROTE:Hi Ravinath,
hye..finally i made it..anyway thanks for your concern :)
Ravinath
Postby ober » Sun Dec 03, 2017 6:36 am
Good to hear that, mind to share what is the problem or mistake? I am sure others will benefit from your sharing.
Postby Ravinath » Mon Dec 04, 2017 10:30 pm
ober WROTE:Good to hear that, mind to share what is the problem or mistake? I am sure others will benefit from your sharing.
Yeah initially I set the switch in B position in GD02 rev 2.0 driver.After I switch it to A then it starts to work. 8-)
Ravinath
