Adding regulated 5V to the Maker Uno
Postby lowfuyuan » Tue Apr 03, 2018 7:26 am
Dear admin,
I am undergoing my personal project where I want to use the 5V output from the LN298N Motor Driver Module to the Maker Uno.
Can I know a way to use this power supply to the Maker Uno as I don't see a Vin?
I have also tried plugging the voltage to the 5V pin but it doesn't work.
lowfuyuan
Re: Adding regulated 5V to the Maker Uno
Postby Idris » Wed Apr 04, 2018 9:18 am
Hi lowfuyuan,
Yes you can use regulated 5V from L298N Dual H Bridge Motor/Stepper Driver to power up your Maker UNO. Just connect 5V & GND from driver to 5V & GND pin at Maker UNO. I also do the same connection at my Maker UNO Bluetooth Mobile Robot.
P/s: Make sure the mini jumper (black) at the back of Vin-GND connector is connected.
Postby lowfuyuan » Wed Apr 04, 2018 10:14 pm
Thanks Idris.
I have tried it before but it wasn't working at first. But now it's working already!
lowfuyuan
