LoRa Shield Modulation Setting
Postby hazirulz » Mon Apr 23, 2018 1:54 pm
Hi, I am wondering if I can change the modulation setting such as using FSK and GFSK while using the Cytron Lora Shield as this shield is based on RN2903 chip. I referred to the chip's datasheet (http://ww1.microchip.com/downloads/en/DeviceDoc/50002390E.pdf) and found that this chip support FSK and GFSK. If possible, can anyone guide me on how to change the modulation settings? Thank you for your time
hazirulz
Re: LoRa Shield Modulation Setting
Postby ober » Tue Apr 24, 2018 6:42 am
You can actually check out the documents under Microchip website: http://www.microchip.com/wwwproducts/en/RN2903
Postby hazirulz » Fri Apr 27, 2018 12:40 am
Thanks! I was looking for at the wrong document all this time.
hazirulz
Postby hazirulz » Mon Apr 30, 2018 10:03 pm
Im still having problems in changing the transmission mode from LoRa to FSK/GFSK even though I have referred to the command reference document (http://ww1.microchip.com/downloads/en/DeviceDoc/40001811A.pdf) but I dont know how to input those commands.
hazirulz
Postby bengchet » Thu May 03, 2018 2:56 pm
It is using UART Interface. So just input exactly the command using UART.
If you are using Arduino, it is like
Serial.println("radio set mod fsk");
But I would suggest you try other commands before trying this, such as "sys get ver", "sys reset", etc to make sure you can communicate with the module. Check page 12 of the document for UART Interface settings.
