LoRa Shield Modulation Setting
Mon Apr 23, 2018 1:54 pm
by hazirulz
Hi, I am wondering if I can change the modulation setting such as using FSK and GFSK while using the Cytron Lora Shield as this shield is based on RN2903 chip. I referred to the chip's datasheet (
http://ww1.microchip.com/downloads/en/DeviceDoc/50002390E.pdf) and found that this chip support FSK and GFSK. If possible, can anyone guide me on how to change the modulation settings? Thank you for your time
Re: LoRa Shield Modulation Setting
Tue Apr 24, 2018 6:42 am
by ober
You can actually check out the documents under Microchip website:
http://www.microchip.com/wwwproducts/en/RN2903
Fri Apr 27, 2018 12:40 am
by hazirulz
Thanks! I was looking for at the wrong document all this time.
Mon Apr 30, 2018 10:03 pm
by hazirulz
Im still having problems in changing the transmission mode from LoRa to FSK/GFSK even though I have referred to the command reference document (
http://ww1.microchip.com/downloads/en/DeviceDoc/40001811A.pdf) but I dont know how to input those commands.
Thu May 03, 2018 2:56 pm
by bengchet
It is using UART Interface. So just input exactly the command using UART.
If you are using Arduino, it is like
Serial.println("radio set mod fsk");
But I would suggest you try other commands before trying this, such as "sys get ver", "sys reset", etc to make sure you can communicate with the module. Check page 12 of the document for UART Interface settings.
