DHT11 for CT-ARM
DHT11 for CT-ARM
Postby JayJoe » Fri Jun 29, 2018 12:41 am
I am having error while compiling dht library for CT-ARM. Please refer the attached files.
Thank you.
dht11_test.rar
(3.81 KiB) Downloaded 563 times
JayJoe
Re: DHT11 for CT-ARM
Postby bengchet » Fri Jun 29, 2018 8:08 am
A quick fix on dht.cpp should do trick, but still need to verify the result.
#if defined(__NUC131__)
    // 32 bit
    uint32_t bit = digitalPinToBitMask(pin);
    GPIO_T* port = digitalPinToPort(pin);
    volatile uint32_t *PIR = portInputRegister(port);
#else
    uint8_t bit = digitalPinToBitMask(pin);
    uint8_t port = digitalPinToPort(pin);
    volatile uint8_t *PIR = portInputRegister(port);
#endif
Postby JayJoe » Sat Jun 30, 2018 2:58 pm
I have verified. Unfortunately, it's not working.
DHT TEST PROGRAM
LIBRARY VERSION: 0.1.28
Type, status, Humidity (%), Temperature (C)
DHT11, Connect error, 0.0, 0.0
DHT11, Time out error, 0.0, 0.0
I am getting these
JayJoe
Postby bengchet » Sun Jul 01, 2018 9:32 pm
Right now I don't have device with me. I will try later and feedback to you. Anyway you can try the library by using digitalRead and see if result is okay.
Postby JayJoe » Mon Jul 02, 2018 1:44 pm
Hi bengchet,
I am using DHT.h library by Adafruit now and it works :D
Thanks for your reply.
JayJoe
