Can 2 MDDS30 controlled by 1 controller?
Mon Oct 08, 2018 1:10 pm
by farr
Can 2 MDDS 30 connected to 12V DC motor and finally connected to 1 controller. And how about the coding available in the github for MDDS 30? Is it still can be used for 4 tires since the coding available in the library is just for 2 tires. How can I modify them? Or is there any coding for 4 tires that you like share?
Re: Can 2 MDDS30 controlled by 1 controller?
Thu Oct 11, 2018 12:41 pm
by ober
It depends how you want those 4 motors to be controlled. Speed? Direction? If all 4 motors need to be independently control with different speed, direction, then your controller will need to have 4 PWM and 4 DIR (digital output), and that is possible. As for the code, I believe is quite straight forward, just modify and look at the output, assign the pin according to the connection.
