Trying to use cuteduino as a remote control
Postby lowfuyuan » Fri Feb 22, 2019 3:27 pm
Hi, I am trying to use my cuteduino to be a remote control for my robot via 433MHz transmitter and receiver. I attached pull-down resistor button to pin 1,2,3 and 4. pin 0 is used for the transmitter. I tested it and realise that the pin 3 button keep transmitting its message as if its pressed on. i tried pressing pin 4 button but nothing worked. pin 1 and 2 buttons is working normally. After doing a bit of research, I realise the issue could have been that pin 3 and 4 is used for USB comm. So i replaced my power supply from USB to battery but the issue remain. Could I know how to allow pin 3 and pin 4 be used a normal digital pin?
Here is the code that runs in the cuteduino:
#include <VirtualWire.h>
  // Initialize the IO and ISR
  vw_set_tx_pin(0);
  vw_setup(2000); // Bits per sec
  pinMode(1, INPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  int button = 0;
 if (digitalRead(1)) {
  send("001");
 else if (digitalRead(2)) {
  send("010");
 else if (digitalRead(3)) {
  send("011");
 else if (digitalRead(4)) {
  send("100");
 else {
  send("000");
  delay(1000);
void send (char *message)
  vw_send((uint8_t *)message, strlen(message));
  vw_wait_tx(); // Wait until the whole message is gone
Here is the code at the receiver end:
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
  vw_set_rx_pin(A0);
  Serial.println("Device is ready");
  vw_rx_start(); // Start the receiver
  if (vw_get_message(message, &messageLength)) // Non-blocking
    Serial.print("Received: ");
    for (int i = 0; i < messageLength; i++)
      Serial.write(message[i]);
    Serial.println();
The arrangement of button
The serial monitor readings
lowfuyuan
Re: Trying to use cuteduino as a remote control
Postby lowfuyuan » Fri Feb 22, 2019 3:50 pm
Hi , sorry I just found the solution for it.
It's from this link.
https://www.reddit.com/r/arduino/comments/28tjjz/need_some_help_with_digitalread_on_pin3_of/
Apparently there is a pull-up resistor in pin 3 and i just need to rewire it to be a pull up button and change my code.
I will just leave the post here and see what the admin will do.(Whether it will be deleted or not)
lowfuyuan
Postby ober » Mon Feb 25, 2019 7:29 pm
Good to know you manage to fix it!
