ARM Cortex M0 doesn't work with Ethernet?
Postby bjp » Sun Oct 04, 2020 4:25 am
I'm trying to compile a sketch that uses the Ethernet.h Arduino library for my Cytron ARM Cortex M0 Arduino but I'm getting the following errors:
Arduino: 1.8.13 (Windows 10), Board: "CT-ARM"
libraries\Ethernet\utility\w5100.cpp.o: In function `SPIClass::transfer(void*, unsigned int, SPITransferMode)':
C:\Users\bjpca\AppData\Local\Arduino15\packages\cytron\hardware\arm\1.1.0\libraries\SPI/SPI.h:76: undefined reference to `SPIClass::transfer(unsigned char, void*, unsigned int, SPITransferMode)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board CT-ARM.
I can successfully build, upload, and run the Blink example, and this sketch works fine on a standard Uno. What should I do to get it to work on the Cytron?
bjp
Re: ARM Cortex M0 doesn't work with Ethernet?
Postby Idris » Mon Oct 05, 2020 10:28 am
Hi bjp,
It seems like the library is not compatible. If you wish to involve internet on your project using CT-ARM, I suggest to use with Cytron ESP8266 WiFi Shield.
Hope this helps.
