How to config i2c in fast mode on CT-ARM
Hi all,
im having problem to configure the i2c mode into fast mode.
I tried to use the same method with normal wire libraries which calling the setClock function, & i got an error stated that there is no member of function setClock inside wire class. i look into the libraries CT-ARM source file and there is no setClock function.
For the CT-ARM, do anyone know on how to configure i2c bus into fast mode??
