How to Use PS2 Shield with Atmega2560 instead of using UNO
Postby luqman » Thu Nov 19, 2020 7:06 am
How to Use PS2 Shield with Atmega2560 instead of using UNO. i tried stacking PS2 shield and Atmega like stacking it with UNO. i tried the example code but nothing happen when i pressed the button. but it works just fine with UNO
luqman
Re: How to Use PS2 Shield with Atmega2560 instead of using U
Postby ober » Thu Nov 26, 2020 2:04 pm
I believe you need to check the UART pin of MEGA with UNO. You need to configure the correct UART pin that matches the mini jumpers on the PS2 Shield.
