Tic-tac-toe Game Based on Arduino and HMI
Materials required for the experiment
Arduino UNO
Stone STWI070WT-01 TFT LCD display
The system principle
Specify the first tap on the screen must be O, the second tap on the screen is X, has been doing this cycle. Set 8 arrays to store the number of O and X in each row, column and diagonal of each grid, as long as there are three of the same mark is the victory, then there will be a flashing red box to prove the victory of the row, column or diagonal, and then tap reset to start the game again.
Simple connection diagram
GUI design
code sharing
demo video
https://www.youtube.com/watch?v=inMMf5RX6Xs
Arduino UNO
GUI design
code sharing
- CODE: SELECT_ALL_CODE
unsigned int r_flag1 = 0;
uint8_t RecievedTemp1[30] = {0};
//uint8_t *RecievedTemp1 = new uint8_t[30];
uint8_t cout_i = 0;
unsigned int quan_hang1 = 0;
unsigned int quan_hang2 = 0;
unsigned int quan_hang3 = 0;
unsigned int quan_lie1 = 0;
unsigned int quan_lie2 = 0;
unsigned int quan_lie3 = 0;
unsigned int quan_zuoxia = 0;
unsigned int quan_youxia = 0;
//unsigned int quan[8]={0};
unsigned int cha_hang1 = 0;
unsigned int cha_hang2 = 0;
unsigned int cha_hang3 = 0;
unsigned int cha_lie1 = 0;
unsigned int cha_lie2 = 0;
unsigned int cha_lie3 = 0;
unsigned int cha_zuoxia = 0;
unsigned int cha_youxia = 0;
unsigned int cha[8]={0};
Serial.begin(115200);
for(int i=3; i<=8; i++)
pinMode(i,OUTPUT);
void loop(){
if(Serial.available() != 0)
// for(cout_i = 0; cout_i < 30; cout_i ++)
// //RecievedTemp1[cout_i] = Serial.readBytes(RecievedTemp1, 15);
// Serial.readBytes(RecievedTemp1, 20);
// //Serial.println(RecievedTemp1[cout_i]);
for(cout_i = 0; cout_i < 19; cout_i ++)
switch(RecievedTemp1[13])
case 49:
if((r_flag1 == 0)&&(RecievedTemp1[14]==2))
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang1++;
quan_lie1++;
quan_youxia++;
// quan[0]++;
// quan[3]++;
// quan[7]++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button1\",\"enable\":false}>ET"));
else if((r_flag1 == 1)&&(RecievedTemp1[14]==2))
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang1++;
cha_lie1++;
cha_youxia++;
// cha[0]++;
// cha[3]++;
// cha[7]++;
break;
case 50:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang1++;
quan_lie2++;
// quan[0]++;
// quan[4]++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button2\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang1++;
cha_lie2++;
// cha[0]++;
// cha[4]++;
break;
case 51:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang1++;
quan_lie3++;
quan_zuoxia++;
// quan[0]++;
// quan[5]++;
// quan[6]++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button3\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang1++;
cha_lie3++;
cha_zuoxia++;
// cha[0]++;
// cha[5]++;
// cha[6]++;
break;
case 52:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang2++;
quan_lie1++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button4\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang2++;
cha_lie1++;
break;
case 53:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang2++;
quan_lie2++;
quan_zuoxia++;
quan_youxia++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button5\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang2++;
cha_lie2++;
cha_zuoxia++;
cha_youxia++;
break;
case 54:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang2++;
quan_lie3++;
// quan[1]++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button6\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang2++;
cha_lie3++;
break;
case 55:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang3++;
quan_lie1++;
quan_zuoxia++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button7\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang3++;
cha_lie1++;
cha_zuoxia++;
break;
case 56:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang3++;
quan_lie2++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button8\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang3++;
cha_lie2++;
break;
case 57:
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"circle\"}>ET"));
r_flag1 = 1;
quan_hang3++;
quan_lie3++;
quan_youxia++;
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button9\",\"enable\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"x\"}>ET"));
r_flag1 = 0;
cha_hang3++;
cha_lie3++;
cha_youxia++;
break;
case 48:
r_flag1 = 0;
quan_hang1=quan_hang2=quan_hang3=cha_hang1=cha_hang2=cha_hang3=0;
quan_lie1=quan_lie2=quan_lie3=cha_lie1=cha_lie2=cha_lie3=0;
quan_zuoxia=quan_youxia=cha_zuoxia=cha_youxia=0;
// for(char count_i=50;count_i<58;count_i++)
// Serial.println((("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image%c\",\"image\":\"bai\"}>ET"),count_i));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"bai\"}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif4\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif5\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif6\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif7\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif8\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif9\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif10\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif11\",\"visible\":false}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button9\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button8\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button7\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button6\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button5\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button4\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button3\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button2\",\"enable\":true}>ET"));
Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button1\",\"enable\":true}>ET"));
break;
if((quan_hang1==3)||(cha_hang1==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif4\",\"visible\":true}>ET"));
else if((quan_hang2==3)||(cha_hang2==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif5\",\"visible\":true}>ET"));
else if((quan_hang3==3)||(cha_hang3==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif6\",\"visible\":true}>ET"));
else if((quan_lie1==3)||(cha_lie1==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif7\",\"visible\":true}>ET"));
else if((quan_lie2==3)||(cha_lie2==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif8\",\"visible\":true}>ET"));
else if((quan_lie3==3)||(cha_lie3==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif9\",\"visible\":true}>ET"));
else if((quan_zuoxia==3)||(cha_zuoxia==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif11\",\"visible\":true}>ET"));
else if((quan_youxia==3)||(cha_youxia==3))
Serial.println(F("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif10\",\"visible\":true}>ET"));
demo video
